Salta al contenuto principale
Rilasciato ad aprile 2014, questo Oppo Find 7a da 16 GB è la versione più economica dell'Oppo Find 7. Per distinguere il Find 7a dal 7, rimuovi il pannello posteriore e la batteria. Dovrebbero essere presenti due adesivi con il numero di serie che riportano la dicitura X9000 dove la batteria si inserisce a filo nel telefono.
change lens back camera
How can i change the lens of the back camera of my oppo find 7a??
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
1 Risposta
It isn't very hard. You can buy lens replacement on aliexpress or another Chinese site. To replace lens you have to follow these steps:
1. Take out back cover
2. Remove battery
3. Remove SD card
4. Remove all Phillips screws from back of the phone (some might be hidden under rubber caps - see other guides with photos .
5. Pry open the internal back chassis starting from a place near power button (credit card is a great tool for it. Don't use anything metal)
6. The lens is glued to the part you just pried open.
9. Detach the lens (well in fact it is a glass cover with UV filter) by applying some force from internal side of the back chassis to the glass - it should be quite easily pushed outside of the back chassis
10. The replacement lens should come with a glue ring.
11. Apply the glue ring to the side of the lens marked by white dot. Be careful to align it properly before applying. You don't want to make lens dirty, especially from the side facing internals of the phone.
12. Put the lens in the hole, glue down.
13. If required clean the lens from inside. You won't be able to do it later. Make sure there is no trace of glue, dirt, smudges or dust particles.
14. Put the back chassis in place. Press it until it clicks in place.
15. Reapply the screws
16. Insert SD card
17. Insert battery
18. Reattach back cover
Congrats, you just did great!
Punteggio 0
Aggiungi la tua risposta
rudydellefave sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 16
Tutti i Tempi: 1,669
