Salta al contenuto principale
iPhone di quarta generazione. La riparazione è semplice, ma il vetro anteriore e l'LCD andranno sostituiti insieme. GSM / 8, 16, or 32 GB di memoria / Modello A1332 / Nero e Bianco.
My LED flash is out of place. Possible to move?
My LED flash on my iPhone 16GB is not centered in the hole. When you look straight at the LED from the back, you can see the LED is higher than where it should be. You can see some blackness under it too inside the hole. It's really noticeable when you take close pictures in the dark, as part of the picture (upper part) is darkened. It just doesn't look even.
I was wondering if I could unscrew the back and move the flash around? Help is appreciated. (It's minor, but it's annoying)
Thanks
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta Più Utile
The flash appears to be attached to the camera. If you take the camera out, you may be able to bend the flash back into its proper position. You may also have a faulty back plate. If the hole in the back glass is out of place, it would make the LED appear to be out of place.
Here is the guide for the the camera.
If it turns out to be a faulty back glass, then you will need to replace the back glass, or of course, return it to Apple. Here is the guide for the back glass.
Immagine iPhone 4 Pannello posteriore
Guida
Sostituzione pannello posteriore iPhone 4
Difficoltà:
Facile
2 - 5 minutes
Immagine iPhone 4 Rear Camera
Guida
iPhone 4 Rear Camera Replacement
Difficoltà:
Moderato
Punteggio 1
1 Commento:
+ Ralph
da
Aggiungi la tua risposta
Nathan sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,575
