Salta al contenuto principale
La Nikon Coolpix S8200 è dotata di un obiettivo con zoom ottico 14X, un monitor da 7,5 cm e pesa circa 215 g.
Keep getting "lens error" message
With my Coolpix S8200 camera, I keep getting "lens error" on my screen. I have turned my camera off and on multiple times and replaced the battery with a new one but nothing seems to be helping. Is there anything I could do to try and get this camera working again?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
If you have already tried restarting the camera as well as replacing the battery, then the next step in the process would be trying to replace the lens of the camera. You should be able to follow the steps for this process on ifixit. If there is not a guide on how to replace this part or if this solution also fails, then the next step would most likely be replacing the camera itself. Hope this helps.
Punteggio 1
Aggiungi la tua risposta
Ashley Wilbur sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 10
Tutti i Tempi: 1,165
