Salta al contenuto principale
L’Acer Iconia One 7 è un tablet rilasciato nell’aprile 2014. L’Iconia One 7 è un dispositivo compatto pieno di divertimento multimediale. Con un display più grande di un phablet che è al contempo nitido e colorato, ottieni una risposta rapida e ore di autonomia della batteria per continuare a usarlo. Abbiamo anche incluso la nostra piattaforma Kids Center con molti contenuti interessanti per i bambini che i genitori possono controllare.
Acer Iconia One 7 Screen Digitizer Video Tutorial
Could you please make a Screen Digitizer replacement video Tutorial for Acer Iconia B1-730 ? is there any model that has similiar process of digitizer replacement and already published in your youtube channel ?
Questa è una buona domanda?
Punteggio 3
Aggiungi un commento
4 Risposte
Risposta più utile
Hi There, I am looking for the exact same tutorial. Were you able to locate one?
Punteggio 1
I haven't found one. So I tried myself the replacement seeing similar tutorials with great success. Now, the tablet is working again with a new digitizer, however I still have a problem with the screen calibration. The digitizer is working good, however when I point my finger on it, the command is recognized in a different position, some centimeters above from my finger position. Anybody knows how to fix it ?
Punteggio 0
5 Commenti:
Hi, Did you ever sort this - I am doing a repair and have the same issue! on two different digitizers!
da Condividi
Nop. Problem still remains.
da Condividi
I have decided that the digitizers sent are not 100% correct. They appear to fit perfectly but they do mask the edges of the lcd slightly. Tried a 3rd digitiser and still the same issue. I have a new tablet coming and will compare the digitiser measurments.
da Condividi
Looks like the only available digitizers are not 100% the same size, The side borders are too wide so obscure some of the lcd and the heights are a bit thick too. Has anyone replaced a digitizer with a ebay special and it work ok?
da Condividi
Hi Jon... the same happened here with my digitizer. The measures is not the same like the original one.
da Condividi
I want to repair my acer iconia tab 8 but i dont know where to found à new screen cam someone help m,e :( ?
Punteggio 0
I wanna ask on what button should I select to organize my apps?? Thank you
Punteggio 0
Aggiungi la tua risposta
ricartengenheiro sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 17
Tutti i Tempi: 2,497
