Salta al contenuto principale
La macchina per caffè Keurig B77 è una macchina per caffè a tazza singola prodotta dall'azienda Keurig.
Unit will not turn on
Unit suddenly will not function after working fine 1 hour ago. The touch button to turn the unit on will not light up and their is no display on the screen
Questa è una buona domanda?
Punteggio 18
1 Commento:
We have a problem about the same. Our power company installed a new transformer on our line and the unit worked prior to that then nothing we've tested the outlet and it's fine. Can we re-boot the unit?
da
Aggiungi un commento
5 Risposte
no power to unit whats up ? is there i fuse somewhere
Punteggio 0
I have the same problem, just got this coffee maker. Worked fine for a day, then it started acting weird. It wouldn't brew every time I pressed the button. Then all the sudden it stopped working and the screen wouldn't come on. Ridiculous!
Punteggio 0
1 Commento:
I'm having the same issue. My unit is a couple years old. Where can I take it to be repaired? Is it completely kaput or repairable?
da
Defective on-off switch
Punteggio 0
1 Commento:
how do I fix that ?
da
My keurig coffee maker will not turn on anymore . I had just used it to make a cup of coffee ,for the next one it would not start.
Punteggio 0
Blue light Screen no writing on screen
Punteggio 0
Aggiungi la tua risposta
Neil sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 32
Tutti i Tempi: 3,907
