Salta al contenuto principale
La EOS 5D è un corpo macchina per fotocamera reflex digitale (DSLR) da 12,8 megapixel prodotta da Canon. Rilasciata nel quarto trimestre del 2005.
Flash will not pop up
The flash no longer pops up, when it should.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
6 Risposte
Risposta più utile
5D doesn't have a built flash.
Punteggio 1
Adjust the hotshoe. Loosen it off and check the contact in the middle, as is sometimes stays depressed/gets caught when you remove the external flash. The camera thinks it has a flash attached and prevents the pop-up flash from coming up.
Punteggio 0
The 5d doesn't have a built in flash. You need to fit an external flash!
Punteggio 0
Hi Sally,
The Canon 5D is a full frame DSLR camera and has no built-in flash. So, I am assuming you are talking about an external flash (like a Canon Speedlite) which you attach to the hot shoe of the camera.
Tell us more about the flash (brand, type, etc.) and what settings you used when the issue occurred.
Punteggio 0
i think u have to get a external camera for this device
Punteggio 0
Eos 5 film had a pop up, but not the 5D
Update (09/11/2022)
My Eos 500d has a pop up... Are you confusing the 5d
with the 500d??
Punteggio 0
1 Commento:
with the 500d??
da
Aggiungi la tua risposta
Sally sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 14
Tutti i Tempi: 1,057
