Salta al contenuto principale
Guide di riparazione e assistenza per il BT 350 Digital Baby Monitor Lightshow.
Baby monitor lcd screen blank?
The parent handset on my bt 350 baby monitor and pacifyer has gone blank all the buttons work but can't see anything on screen .can anyone help please.
Questa è una buona domanda?
Punteggio -1
1 Commento:
This seems to be a common problem so any help for us mums would be great .Thank you
da
Aggiungi un commento
1 Risposta
Hmm i am not familiar with baby monitors but first i would check the power source . test the adapter to make sure it is supplying power or remove the batteries and check the terminals . sometimes the terminals might need a little pry to touch the battery again. Other than that i would suspect an internal issue which would require you to take it apart and look for damage such as loose or broken wires . any black residue on the board anywhere, leaking capacitors blown fuses. wish i could be of more help.
Punteggio 0
Aggiungi la tua risposta
glynis950 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 4
Ultimi 30 giorni: 15
Tutti i Tempi: 2,675
