Salta al contenuto principale
Il primo tablet della famiglia Acer Iconia Tab B1, l'Acer Iconia Tab B1-A71, è stato annunciato a gennaio 2013.
How to replace charging port?
Im attempting a charging port replacement on the tablet, i've got the old charging port off without any issues however I can't get the mounting holes free from solder to fit the new charging port in.
Could anyone advise on what I could try, tried solder wick but doesn't help much as I can't get enough heat into the solder between the holes
Immagine
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Position the new port with its feet in place, then heat the area (I used a heat gun carefully) while applying a little bit of pressure with a pair of tweezers.
The solder (or whatever it is) will soften with the heat and the port will sink in. Remember to remove the yellow tape from the topside first!
Punteggio 0
Aggiungi la tua risposta
EvansITLtd sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 12
Tutti i Tempi: 2,316
