Salta al contenuto principale
Rilasciato il 24 ottobre 2011 / Processore Quad-core Intel Core i7 da 2,2, 2,4 o 2,5 GHz
Best RAM for MacBook Pro Late 2011?
Have a Mac Book Pro Late 2011 15" and would like to upgrade the RAM if possible, what is the best type I can install and is it true that I can put in 16GB's instead of 8GB's?
Thanks!
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
3 Risposte
Soluzione prescelta
RAM Type: PC3-10600 DDR3 Min. RAM Speed: 1333 MHz
Details: Supports 1333 MHz PC3-10600 DDR3 SDRAM.
Standard RAM: 4 GB Maximum RAM: 16 GB*
Details: 4 GB of RAM is installed as two 2 GB modules, no slots free.
*Apple officially supports a maximum of 8 GB of RAM, but third-parties have determined that this model actually is capable of using up to 16 GB of RAM with two 8 GB memory modules.
Punteggio 7
Best RAM upgrade is an SSD, if it doesn't have an SSD it will still be unbearably slow after the RAM upgrade. You can get 16 GB in this machine though.
Punteggio 1
I am using 2x8GB 1600MHz RAM modules in this MacBook Pro. Works noticeably faster than the standard 1333MHz.
Update (02/05/2022)
I used the 16GB config for nearly 2 years and never noticed overheating problems. The RAM was stable and the machine worked so well that at some point I wasn’t aware anymore of the modified configuration (now 2x8GB at 1600)!
I sold the machine in the end due Mac upgrade. RAM never failed on me, the system worked fine (no overheating as I applied new thermal paste way before the RAM upgrade (Arctic Silver, I recall?)).
Just in case I would get my hands on one of the 2011 MacBook Pro again, I would do the same thing: new thermal paste and RAM upgrade. After SSD upgrades (Bay 1 SATA 3 and Bay 2 SATA 2) this RAM change was hands down the best upgrade.
Punteggio 0
7 Commenti:
Hi, I have same config, but have seen considerable amount of overheating even after cleaning up and applying new thermal compound. This when running heavy processor intensive apps. Do you see same problem?
da
really? hows it holding up? im considering an upgrade very soon
da
HI, any recommendations for 16gb ram modules for my macbook pro 2011 late?
da
Hi! How's your machine holding up these RAM modules so far? I've got 8GB 1333Mhz but about to double it and seeing people using 1600Mhz modules is even more exciting!
Can other users who have done the same share their experiences too?! I'd really appreciate!
da
@tenninshi I found some archive pages of mac forums in which some users have reported the 1600MHz RAM officially supported only by the 2012 models being recognized and working perfectly well on the 2011. As for the hardware actually using it to its full advantage it's not easy to tell.
I'm also planning on using 2012 spec RAM on my recently restored 2011, the 16GB sticks I have are old and some of the pins have started to rust and have given me some boot issues along with errors in memory tests.
For some reason the entire computer feels "weirder" than before I dismantled it and mothballed the restoration 2 years ago. Maybe the humidity is killing it.
da
Mostra 2 altri commenti
Aggiungi la tua risposta
airforce49 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 41
Tutti i Tempi: 16,521
