Salta al contenuto principale
Lanciato il 28 luglio 2014, il Samsung Galaxy S5 mini è uno smartphone dotato di fotocamera posteriore da 8 MP, schermo 720p, lettore impronte digitali e resistenza all'acqua. Rispetto al suo fratello maggiore, il Galaxy S5, ha uno schermo più grande, maggiore autonomia della batteria e una fotocamera con aggiornamento.
Contacts for wireless charging?
Hi,
can anyone tell with certainty whether the two pins in the upper left battery corner (just above the microSD slot) are intended for wireless charging? They seem a little too close to each other. Allegedly, Samsung support stated they indeed are meant for QI charging, others claim it would only be for the S-view cover. Germanys Samsung support refuses to tell me anything about the purpose of these contacts. Testing with a multimeter reveals that at least one of them has electrical contact to the battery.
So, if they really are intended for wireless charging and Samsung dropped wireless charging for the S5 mini, it should be possible make it charge wirelessly with an appropriate coil and some copper foil to match the contacts. Otherwise, if this would be possible, I guess there already would be some chinese manufacterers selling pre-build receivers which do match the contacts.
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
1 Risposta
Nooooooo......... you Cant with s5 Mini wireless charging..
Punteggio 0
Aggiungi la tua risposta
Philman sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 21
Tutti i Tempi: 4,989
