screen touch does not work after replacement?
I replaced the screen and digitizer and the screen comes on but touch doesn't work. I've checked all connections twice. What could it be?
Questa è una buona domanda?
jeyson, if you are sure that all your connections are properly seated, I would contact the vendor and replace the assembly once more. Sadly enough, it is not uncommon to receive a bad digitizer. Of course, you always want to double check your work, check to make sure that there are no bend or broken pins on the connector.
Ultime 24 ore: 1
Ultimi 7 giorni: 1
Ultimi 30 giorni: 13
Tutti i Tempi: 1,590
3 Commenti
Jeyson......did you end up fixing this problem??
da Jason Gonzalez
I have the same issue. My ZTE zmax pro z981 screen broke and I bought 2 new screens and after I put new screen it lights up but doesnt respond to any commands
da Nikola Tesla
I have the same problem except mine's a ZTE n9521 screen not responding to touch
da br700973
