Salta al contenuto principale
Il Toshiba Satellite L300 era un notebook progettato e venduto da Toshiba, fornito con una versione di Windows Vista. È stato venduto tra maggio e giugno del 2009 e, sebbene non fosse idoneo per l'aggiornamento gratuito a Windows 7, è passato molto tempo e gli aggiornamenti non sono più richiedibili; il dispositivo esegue correttamente Windows 7 Home Premium senza aggiornamenti, principalmente a causa dell'eccessivo consumo di risorse di Vista. Conosciuto anche come Toshiba Satellite L300-04P (PSLB8C-04P01X).
Power supply won't connect
Hi
The post inside my laptop that the power cord goes onto doesn't seem to make a connection anymore. If you put something in there you can see that the post moves around pretty freely so it must have either broken or come loose. Is there a way for me to fix this or do I need to find a repair centre?
Thanks!!
Questa è una buona domanda?
Punteggio 3
1 Commento
I have the qosmio x75 and it stopped all together, no charge light, no light, and no screen, any suggestions on what to do to fix. Please
da
Aggiungi un commento
5 Risposte
Soluzione prescelta
Hi, This seems to be a common problem with the Toshiba. Here is a link to a successful mod to repair the problem. Please pay special attention to the cautions the modder makes and read all the way through before deciding to do this. Good luck. Ralph
http://www.insidemylaptop.com/repair-dam...
Punteggio 3
1 Commento:
+ for doing the work others didn't
da
After you take apart the laptop, if it is just a loose connector, you should be able to just solder it back in place.
Punteggio 0
I have this happening to my Toshiba again - third time since I began using it in December 09. Going to try the workaround to see if I can avoid buying yet ANOTHER power supply. Thanks!
Punteggio 0
It says something like my adapter broke
Punteggio 0
Using Toshiba Satellite Radius 14 and worst laptop ever. Power cord doesn't keep connection after 1 year and on their website they want $55! The screen broke on one side at 7 months when your supposed to be able to make a tablet, never again.
Punteggio 0
Aggiungi la tua risposta
nicksmom1962 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 20
Tutti i Tempi: 32,337
