Salta al contenuto principale
La Nikon D80 è una fotocamera digitale a obiettivo singolo da 10,2 megapixel, rilasciata al pubblico nel 2005. È destinata a scattare foto e girare filmati in formato digitale.
Err code on display . Camera stop responding.
My D80 shows err code. Try to change lens. Try change f stops. Still the same.
Questa è una buona domanda?
Punteggio 3
1 Commento
my cam had the same issue got it repaired at very less price at mata electronics. contact them at mataelectronics@Gmail.com
da Condividi
Aggiungi un commento
1 Risposta
Risposta più utile
Usually, on a Nikon D80 with an "err" message that won't go away, the Aperture Control Unit must be repaired or replaced. There is a small switch contact held on by a small plastic rivet in the Aperture Control Unit that tells the electronics module in the camera what phase the camera is in during its cocking cycle. When that small plastic rivet breaks, the camera can't determine where it is in the cycle and just stops and displays the "err" message.
There are 2 ways of fixing the problem, replacing the part with the same weak plastic-riveted switch contact or taking the Aperture Control Unit apart and replacing the plastic rivet with a small steel screw which can't break again. I've been using the second method for many years now and haven't had a single body experience the same problem again.
Bob Kilbourn
http://www.camerarepairs.com
Punteggio 3
1 Commento:
Hey Bob, where did you get this small screw from and what size of screw did you get? Thanks
da Condividi
Aggiungi la tua risposta
AmranNazi sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 22
Tutti i Tempi: 3,356
