Salta al contenuto principale
An aviation themed analog luxury watch from Breitling.
2 Domande Visualizza tutte
removing the bezel safely
How you you remove the bezel of a Breitling Navitimer Safely?
I heard there are screws holding the bezel down. hoo do i find these screws?
the gap between the bezel and case can barely fit a piece of paper. i can't get a knife in there. i plan to use a razor blade and see what happens.
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
3 Risposte
Risposta Più Utile
Again I repeat don't try to use any blade as it could be held be three screws inside if its a later Navitimer.
Whereas the earlier 806 model can be lifted from outside with a proper Watchmakers blade.
Kind Regards,
Tony
Tony Arnold {Director}
arny@helios-electronics.com
Punteggio 1
It depends on the model number etc
kind Regards
Tony
Punteggio 0
Don't use a razor blade, the edge could break and send shards into sensitive tissues, like your eyes. Yikes!
A watchmaker's tool or iFixit's Jimmy tool would be better.
Immagine Jimmy
Prodotto
Jimmy
$7.99
Punteggio 0
Aggiungi la tua risposta
han sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 34
Tutti i Tempi: 2,266
