Salta al contenuto principale
Il Motorola Droid 4 è uno smartphone prodotto da Motorola, rilasciato con Android 2.3 e aggiornabile ad Android 4.1.
damaged battery connection?
Would it have damaged my battery connection when i dropped my phone and it landed hard enough to shatter the screen and threw the battery out of it?
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Risposta più utile
Hi Kip,
I highly doubt that the battery itself is at fault here. Check out the battery guide for the droid 4 here on ifixit: Sostituzione batteria Motorola Droid 4
As you can see, the battery is pretty secure on these devices, and the connection is even secured with two screws. What are some of the issues you are experiencing? If the device is not powering on, you most likely need a new LCD if the fall was hard enough to shatter the screen and make you think the battery got disconnected. As always, more information would be helpful.
Punteggio 1
Aggiungi la tua risposta
Kip sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 7
Tutti i Tempi: 235
