Salta al contenuto principale
Tefal Actifry - Forno a convezione. Lanciata per la prima volta nel 2006, questa friggitrice rivoluzionaria e versatile ti permette di cucinare un'ampia gamma di pasti in modo economico, oltre a essere più sicura e facile da pulire rispetto ad altre friggitrici
Replacing the heating ellement
Replacing the heating ellement in a Tefal Actifry
Questa è una buona domanda?
Punteggio 4
1 Commento:
The paddle stopped turning on mine and after fitting a replacement motor the heater and fan did not work but the paddle did. After careful examination of the circuit board I noticed that the larger of the two fuses had blown. It looks like an antisurge fuse and it was very difficult to see if it was blown but my meter confirmed it was U/S. Unfortunately the fuse needs to be desoldered and a replacement soldered back onto the circuit board. All good afterwards. Tefal need to think about their philosophy and try to make stuff that lasts longer than 12 months and is also easier to repair.
da
Aggiungi un commento
1 Risposta
follow the guide for the paddle motor, the heatin element module can be prised out gently using a screwdriver and the 2 black leads removed from the PCB board.
Punteggio 0
Aggiungi la tua risposta
Mike sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 21
Tutti i Tempi: 4,145
