How do I replace the Black Midframe on the 3ds XL?
I bought a new Black Midframe (the inside black casing) and I want to know how to install it. Please help!
Questa è una buona domanda?
This is a pretty difficult replacement, since it involves opening up both halves of the system.
This is a video on how to fix a cracked hinge by replacing the midframe: https://www.youtube.com/watch?v=dVn_m_OI...
I'd give it a quick watch before deciding whether or not to replace it.
Assuming that you are a beginner to this sort of thing, the risks to damaging your system are pretty high.
(I did this to fix a cracked hinge, and regret not being more careful, as my circle pad no longer works. But now I have an excuse to buy a New 3ds, so I suppose it's not all bad.)
Most steps to the process are in this guide: Sostituzione touchscreen Nintendo 3DS XL
However, in order to re-attach the top screen, you will have to remove its outer shell, as shown in this guide:
Sostituzione schermo LCD superiore Nintendo 3DS XL
From there, just follow the first video, taking care to not damage the wires. These can be slid through a slit in the casing by the hinge.
The main things to watch out for are
- Don't strip any screws. If the screw isn't coming out, try a different screwdriver. Magnetic screwdrivers are pretty helpful here.
- Do not break any of the grey flaps on the motherboard. From what I can tell, these can only be fixed by replacing the entire motherboard, which is one of the more-expensive parts.
Guida
Difficoltà:
Molto difficile
45 minutes - 2 hours
Guida
Difficoltà:
Moderato
1 - 3 hours
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,321
