Salta al contenuto principale
A rotary tool made by the Dremel company. It is model number 395 and runs at 5000-35,000rpm.
Why is my Device not turning on?
I plugged My MultiPro in and no matter what I do it will not turn on. The bit will not rotate and the device seems to not be getting power at all. Can this be fixed?
Questa è una buona domanda?
Punteggio 5
Aggiungi un commento
1 Risposta
Risposta Più Utile
Yes, this problem can be fixed. Ways in which you can fix your dremel and get it to power on are, Making sure the dremel is plugged in, make sure the brushes are properly cleaned, and make sure the stator wires are making a connection with the connector.
Dremel MultiPro 395 Troubleshooting
Punteggio 1
Aggiungi la tua risposta
Matthew Satton sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 14
Tutti i Tempi: 2,480
