Salta al contenuto principale
Rilasciato a maggio 2013. Display - 1200 x 1920 pixel, 10,1 pollici. Chipset - Qualcomm Snapdragon APQ8064, CPU - Quad-core 1.5 GHz Krait, GPU - Adreno 320. Memoria - 16/32 GB, 2 GB RAM. Sistema operativo Android, v4.1.2 (Jelly Bean), aggiornabile a v4.4.2 (KitKat).
screen broken but working
my tablet z touch screen broken, i want any professional guide to change a new screen.
Questa è una buona domanda?
Punteggio 8
Aggiungi un commento
5 Risposte
Risposta più utile
check here https://www.youtube.com/watch?v=2DQpbjzK...
Punteggio 1
1 Commento:
@kozzmic: That video only explains how to replace the full screen (LCD + glass + touch), not just the glass + touch. Seems you can buy the glass + touch digitizer without the LCD, and that makes the repair a lot cheaper, but maybe a bit more complicated: http://www.parts4repair.com/touch-screen...
Here's some insight on how to separate the glass + digitizer from the LCD. Looks like it's easy to do something wrong: https://www.youtube.com/watch?v=levTY6Ix...
da Condividi
:) check this surprise ,
change or replace the front glass only https://youtu.be/-nFy-Ojt8oc
Punteggio 1
i have a broken screen and wish to change it and bye a new one
Punteggio 0
Here's the teardown in full
https://youtu.be/MdwBZ7JBxJ0
My daughter just broke mine... Not amused atm
Punteggio 0
HI!
It's a pain in the ass to do this and i think this dont justify to have the job done.
I used two keychain rings attached in a piece of Nichrome wire because it's very hard to broke.
I heated a little all the tablet and put everytime direct heat in the part i'm with the wire and did the job with very very carefull.
after i thought the worst part is done, i've come with the loca glue removing. I think it's harder than the first part of removing digitizer from LCD. I used Isopropyl alchool and did it finally. but some alchool go to backlight and i can do nothing. The display is now blotched with alchool in some parts.
Conclusion: With very patience you can do this but i don't think it worth the effort.
Immagine
Immagine
Immagine
Punteggio 0
Aggiungi la tua risposta
blacksigma sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 36
Tutti i Tempi: 8,921
