Salta al contenuto principale
Rilasciato a settembre 2013, identificato dal numero di modello T100T. Dispositivo portatile 2-in-1 con processore Quad core Intel® Atom™ e 2 GB di RAM.
Replacing of hard drive
Location, replacement, and largest size that can be on tablet on the Asus Transformer T100
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
6 Risposte
Soluzione prescelta
You cannot replace the "hard drive" because it doesn't have one. It has an integrated chip that's solid state. What you can do though, is use a micro sd, and get a OTG (on the go) connector for your micro usb, and connect tons of usb thumbdrive sticks to it, or an external HDD.
Punteggio 4
3 Commenti:
What if your hard drive is working correctly and the administrator is not functioning
da
The tablet itself does not have a hard drive. But the detachable keyboard absolutely DOES have a hdd unit.....
da
I have two of these T100 and neither have a hard drive in the keyboard.. both stuck in bios. When i tried booting the drive it gets error )xc0000001.
da
Dustin is correct for most Asus T100. But Asus does produce a version with a 500GB hard drive installed in the keyboard unit. The standard unit, without the hard drive, is likely a T100TAM-C1. The unit with an installed 500GB drive is a T100TAM-H2.
I am not 100% sure, but I believe all keyboards are wired for the hard drive, regardless if one is installed, or not. So a hard drive can be added to a unit after purchase.
Punteggio 1
2 Commenti:
Sorry, the ASUS Keyboard dock without an HD are too thin and lack the interface for a har drive.
da
Those keyboards are only on the latest units, anything more than a year old does have an hdd installed. I am on my second of these, two different types and sizes, and they both had hdd's installed in their keyboard docks.
da
I believe that the keyboards are interchangeable.
Punteggio 1
I can assure you taht all of the keyboards are NOT the same. Mine does not have the space or the connectors to add a HDD.
Punteggio 0
Well, if it is a model with a hdd, here's a link as to how to replace it.
I was unfortunate enough to have the hdd in my t100ta fail, and this is how you take it out (or perhaps replace it)
Punteggio 0
2 Commenti:
why you were unfortunate , it didnt work ?!!
da
If a replacement keyboard says T100TAM-H2-GM, as mine does, another keyboard with the same number would not have a slot for a HDD?
da
The hard drive is located in the keyboard. My Asus Transformer book T100 has a hard drive problem and i found the location of it during the replacement
Punteggio 0
Aggiungi la tua risposta
Jim Burnett sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 32
Tutti i Tempi: 25,615
