Salta al contenuto principale
Monitor LCD Dell da 19" di colore grigio antracite, uscito nel 2004.
Display darked out in 1 second
My Dell has very similar board layout as this one. It display for about 1 second after each power on and then darked out. Power off and on again give me another second but that's is. I shine a strong light on the screen in the hope that I can see a shadow of the display but nothing. With help from this site, I tear down the case but not able to troubleshoot because of my limited knowledge.
With the power supply board alone (not connect to any other board), tested it and all +5V and +12V output are ok and very stable. Found a pin labled "on/off along the DC out to the controller board (i.e. the one with the VGA port). But no matter I connect ground or +5V to it, the inverter still has nothing out.
Can anybody give me an idea how I can troubleshoot the problem? Thanks in advance.
Immagine
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
senderj, sounds like a bad inverter. You can try to recap the PSU or replace it.
Punteggio 1
Aggiungi la tua risposta
senderj sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 18
Tutti i Tempi: 883
