Salta al contenuto principale
L'HTC One SV è un elegante smartphone Android con funzionalità 4G LTE che unisce un audio di alta qualità grazie al sistema Beats Audio™
Why does an error message keep popping up?
An error message saying my dialer has stopped working keeps popping up. It gives you an option of send a report or don't send and it pops right back up after you pick one of the options.
I had my carrier factory reset it and it did not help. Please help save my phone.
Questa è una buona domanda?
Punteggio 6
Aggiungi un commento
4 Risposte
The issue you are seeing is call "force closing".
If your phone is stock, that is not rooted, then chances are a third party app is causing the problem. If it happens after a factory restore, with no third party apps installed, then you just need to clear the cache.
http://forums.androidcentral.com/verizon...
That's a guide on clearing your cache. You will have to redownload your apps but that should fix it.
Punteggio 0
2 Commenti:
i cant clear my cache in htc one m8 due to marshmallow update
da
? Marshmallow has nothing to do with the stock recovery. You absolutely can still clear your cache after the update.
da
Go to settings then go to apps after that go to running apps and uninstall up date on input sense
Punteggio 0
I am experiencing the same issues with many apps. Email, clock, dialer etc. I am unable to get into settings.
Same error.
What other options are there?
Punteggio 0
SOFTWARE updating problem
Punteggio 0
Aggiungi la tua risposta
Nicole Hallett sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 3
Ultimi 30 giorni: 14
Tutti i Tempi: 11,014
