Salta al contenuto principale
Una macchina per caffè espresso domestica facile da usare, creata da Saeco e rimarcata per Starbucks. Questa macchina è eccellente per chi beve espresso quotidianamente e vanta un'ottima costruzione e durata del prodotto.
Ready light does not come on
The Ready light does not come on anymore. The water does not get hot. The pump does work. Water does come out of the steam dispenser & brew head. I did feel the brew head & it was slightly warm, but never got hot & the ready light never came on after 10- 15 minutes.
Questa è una buona domanda?
Punteggio 2
2 Commenti
Is it under warrenty?
da
No, it is not under warrenty. It is probably 5 or 6 years old.
da
Aggiungi un commento
4 Risposte
Risposta più utile
What barista model do you have???
is it this one?
"normally" - the problem you are describing is the result of a calcified or defective boiler.
if it's the model as shown in the teardown, than you can also search for parts from the Saeco Estro Vapore - it's the same machine
Punteggio 2
If the machine is warming up somewhat but not getting hot then your heating element is probably coated in calcium. You should be descaling roughly every 3 months to prevent this from happening; make sure you use a proper descaling agent (Dezcal/Durgol) as home remedies such as lemon juice or vinegar are not good for the machine.
Punteggio 1
If you’re handy with a few simple tools, replacing the boiler sounds like a good option. Certainly, try to clean it first, but replacement isn’t a tough job either. Read the guides on Ifixit, and search on youtube videos. Parts are pretty common on Ebay, sometimes you can buy a machine just for parts pretty cheap. Just chop shop out a boiler and reinstall it.
Sometimes you get REALLY lucky. I bought a brand new Starbucks Barista SN006, in the box, for $150. I almost fainted when I saw it. Now my old one is is slowly but surely being repaired and cleaned, and my wife isn’t bugging me to fix it!
Punteggio 0
Mine won't start at all replace start button cord is good.
Punteggio 0
1 Commento:
Nora Neese what model is yours. Starbucks Barista xxxxx? Besides the power cord, what have you checked?
da
Aggiungi la tua risposta
Ken sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 4
Ultimi 30 giorni: 14
Tutti i Tempi: 3,576
