Salta al contenuto principale
Tablet Android 4.0 per bambini / cover posteriore blu e parte frontale bianca / rilasciato nel 2012
The touch screen is unresponsive
I keep pushing on the touch screen but nothing moves? What should I do?
Questa è una buona domanda?
Punteggio 5
4 Commenti
It will work with A mouse
da
the glass is cracked will this keep it from working
da
It isnt working not alittle.
da
my screen is cracked and the same thing happening how do I fix this
da
Aggiungi un commento
3 Risposte
Soluzione prescelta
The most likely problem is a loose connection on the inside.
Check the connections of the ribbons on the inside of the device. Follow the motherboard removal guide to get to the ribbons.
If this doesn't work, the digitizer may need to be replaced. However, a guide is currently not available for that. To replace the digitizer, one would follow steps similar to the screen replacement guide, but put the components in a new digitizer.
Immagine Kurio 7
Guida
Guida alla rimozione della scheda madre del Kurio 7
Difficoltà:
Difficile
15 - 25 minutes
Immagine Kurio 7 Schermo
Guida
Sostituzione schermo Kurio 7
Difficoltà:
Moderato
30 - 45 minutes
Punteggio 5
1 Commento:
my tablet is in a sleep mode and will not wake no matter what I do.
Tried on and off, reset button and power and up volume button at the same time and nothing changes
da
Mine is the same as Amos. Sleep mode . Wont wake up.
Punteggio 0
Chicken
Nugget
Watermelon
Punteggio 0
Aggiungi la tua risposta
Omri Nissan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 3
Ultimi 30 giorni: 19
Tutti i Tempi: 9,693
