Salta al contenuto principale
Il Sony Xperia Z è uno smartphone basato su Android rilasciato nel 2013. È uno dei telefoni più grandi della famiglia Xperia, con un display Full HD da 5 pollici. I numeri di modello includono C6603/C6602.
How do I keep I waterproof
How do i replace the full housing with all side flaps and chassis while keeping it waterproof
Questa è una buona domanda?
Punteggio 2
1 Commento
thank you.i already have the original full housing.that was really helpful,i understand that the trick for waterproofing is in the adhesive tape.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
First, buy the original full housing replacement with adhesive sticker.
Then, prepare the back cover adhesive sticker you need, must be original and waterproof.
Next, remove and install the small parts inside carefully and correctly especially pay attention to the headphone jack. If you remove it and you'd better use the glue to fix it when put it back.
At last, press the adhesive stickers between every two parts with much efforts to ensure they are stuck very well.
Sony Xperia Z is not easy to take apart, so be careful enough. Good luck to you!
Punteggio 1
Aggiungi la tua risposta
zein hamza sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 6
Ultimi 30 giorni: 26
Tutti i Tempi: 4,561
