Salta al contenuto principale
15,6", Intel HD Graphics, Core i3 2330M, Windows 7 Home Premium a 64 bit, 4 GB di RAM, HDD da 500 GB
Heat problem
Hello i have a problem in the high-temperature device to 93c
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
1 Risposta
Risposta più utile
sawalha, make sure that you when operate your laptop that you do not occlude the air vents. Keep the laptop off soft materials, like cushions, pillows and blankets. If it still gets hot, you will have to take it apart and clean the air vents, the fan as well as considering replacing the thermal paste on the processor. Start with the cleaning first, then re-evaluate. You can download the service manual from the bottom of this page. Hope this helps, good luck.
Punteggio 2
1 Commento:
Will echo this and say its always good to replace the thermal compound between the heatsink and the CPU. The cheaper stuff stops performing well after a couple of years.
da
Aggiungi la tua risposta
sawalha sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 1
Ultimi 30 giorni: 10
Tutti i Tempi: 1,791
