Salta al contenuto principale
Riparazione di altoparlanti, autoradio, unità principali e lettori CD per auto o camion.
vauxhall meriva radio code
i need a code for my 2004 meriva
Questa è una buona domanda?
Punteggio 13
5 Commenti
I get SAFE but then it shows 6 instead of 10 ? H-E-L-P !
da
You can get a vauxhall radio code here: https://radiocodevault.com/vauxhall/
da
I get safe it show 7 instead of 10
da
كود ٢٤ في سيارة فوكسيل ميريفا ٢٠١١
da
!!! Please !!! HELP !!! Need audio code for OPEL MERIVA, serial number is GM020531818417. Send in mail: pitomiandjeo@gmail.com Thank you!
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
gareth, if you do not have a code, you may want to try this site. If you do have a code try this:"
Entering code into stereo:
Turn Off Stereo
Switch On Ignition (No Need To Start Engine)
Press & Hold Preset " AS " and
Switch Radio On - Display Shows
" SAFE " And Then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press & Hold Preset " AS " Until the Unit Beeps
INsP message:-
Ignition Off
Hold Trip Reset In (keep held in)
Press brake pedal (and keep pressed)
Turn on Ignition
Still Hold Trip Reset and brake pedal for approx 10 seconds, the INSP should change.
release brake and trip reset.
switch off ignition
switch on ignition and check. " hope this helps, good luck.
Punteggio 1
4 Commenti:
Where is trip reset
da
My radio show safe7 not ten
da
My is Siemens 2005 vdi
da
My radio show 9 safe
da
Aggiungi la tua risposta
gareth sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 7
Ultimi 30 giorni: 44
Tutti i Tempi: 34,528
