Salta al contenuto principale
L'HTC Evo 4G LTE è uno smartphone Android sviluppato da HTC Corporation, lanciato in esclusiva da Sprint.
The application (process com.android.vending)has stopped unexpectedly?
Google Play was accidentally uninstalled. I reinstalled it and now get the error message, "The application (process com.android.vending) has stopped unexpectedly. Please try again." Is there a way to save my phone? It's running Android version 4.1. I've only had the phone 4 days.
Questa è una buona domanda?
Punteggio 1008
5 Commenti
A preference file or daemon might have been removed when you deleted Google Play. Google Play is installed with OS. Might not be a good idea to delete this App. I would back up my contacts and important information and just hard rest the phone.
da
Am I tambien me Paso
It happened to me too!
da
To overcome the problem of the palation to be stopped on an Android device, you can do cleaning junk files or applications that are not important.
Or can do the following steps
1. Restart the phone
2. Hard Reset Phone
3. Re-install the phone
For more information, please see the problem at
https://www.mobilintec.net/2019/11/the-c...
da
rivo mobile
problem
da
Encountering the error "The application (process com.android.vending) has stopped unexpectedly"? Clear the cache and data from the Google Play Store app in settings. If the issue persists, restart your device or reinstall the app for a fresh start.
da
Aggiungi un commento
9 Risposte
Soluzione prescelta
Play store can't normally be removed unless root access is granted. If you have root access, just properly install the proper Gapps. Gapps are all Google product apps that are preloaded into a single package for that phone. (They must be installed in recovery.)
If you do not have root access, do a full factory reset.
*****UPDATE*****
For those of you that this does not apply too and your phone was never rooted and is doing this at random, and a factory reset does not work you need to flash a new image to your phone. (ive seen viruses that corrupt the stock rom image so the user could not factory reset to get rid of said virus)
MODEL - PROGRAM
samsung - Kies/kies lite
LG phone - LG PC suite
...more will be added, just google
Punteggio 259
1 Commento:
I fixed it, look up the Google play site on the browser of your phone and enter into it through the browser, search it in Google I don't remember off the top of my head, but you open Google play through the browser not the app. When it opens it fixes the error of not being able to open Google play, and you will now be able to use the app
da
All you have to do is:
1. remove battery
2. remove sd card
3. put battery back in phone
4. turn on phone
5. reset phone
6. wait till phone is fully reset
7. remove battery
8. put sd card back in phone
9. put battery back in phone
10. turn on phone
And that should do it. the downside is that you might lose some apps you downloaded unless they were on your sd card.
Punteggio 62
6 Commenti:
This works. I had the same problem as the person originally stated, and none of the method's but this one worked. Just make sure u backup contacts to your SD card.
Thanks xD
da
if you have dual sim then exchange the position .
da
da
I went to the POWER OFF AND RESTART. when phone came back on, it was fine.
da
What if you can't take battery out
da
Mostra 1 altri commenti
if you have root access
using root browser application delete the folder for com.android.vending
path for which is /data/data/com.android.vending
Punteggio 37
3 Commenti:
thank you very much!!!!! u my life saver!!!
da
Thnk u so mch for yr hlp
da
My google play store has stopped my phone is giving me a problem so plis help me.
da
Listen me. The only one efficient option is Reset your device. But before do it not forget to take backup of your important data like contact numbers, pictures etc. For Reset go to Menu -> Settings-> Privacy-> Factory Reset-> press it.... Thereafter your problem will difinitely solve.
Pramod Kumar Sahu
Punteggio 21
2 Commenti:
oh my god. such a saverrrr. thank you so much.
da
its working thank you sir
da
i tried alot of this answers but all not works still the same
then i found other way to download apps without phone play store
1- open google play on ur computer
2- login using ur google account
3- search from application which app u want
4-install it on ur computer and it will install at ur phone automatically
5-after install u will have message " package not found " press ok then it will open " play store at ur phone
6- download and install all apps u want
thanx
Punteggio 15
1 Commento:
Does anyone know how to fix this on a TV? I am not very good at this stuff but can follow directions. Thank you.
da
Well , actually I too have this problem sometimes ago. I can provide a method, it might also work for you.
Your mobile is a smartphone & working on android, now let's start.
-> Go to "Settings -> (Scroll down a little bit)
-> Application manager or Apps
-> then tap on the menu key(it's on the top right of your screen in new android versions ; three dots) or as
your device suits
-> tap "reset app preferences"
-> Confirm "Reset apps"
-> exit .
It's done .. if it works , good ; no , try searching on internet. :)
Punteggio 10
2 Commenti:
Perfect. It worked for me.
da
Thanks Bibhu, it worked on my android 4.4.2.
I followed as instructed by you. On completion nothing seemed to b happening. I re-booted my ph. It was done. The play store was at place like before. Now ph function is fully OK.
da
Check that you havnt been infected by a VIRUS !
RESETING your device to factory defaults should help you to get rid of a VIRUS, but if you dont know where you infected your device you might get infected again :(
http://androidforums.com/threads/android...
Punteggio 9
1 Commento:
vad ska jag göra med min telrfon smsung 21plus någåt har kontroll på min telefon finns tips
da
Punteggio 3
2 Commenti:
I tried Timmy's advice above and it worked like a charm. Thank you.
da
timmy......your answer worked!!!! thank you so much!!!!!!
da
Reboot the smartphone this will solve your problem.
Punteggio 0
Aggiungi la tua risposta
Shelly Rogers sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 18
Ultimi 30 giorni: 57
Tutti i Tempi: 467,662
