Salta al contenuto principale
Rilasciato a marzo 2006, identificabile dal modello D620 sulla cornice della tastiera.
Computer will not go past "Start Windows Normally"
I got my farther the Dell D620 to start him off with, he was online when the battery went dead and turned off. I plugged it in and started it back up, it went to the "Start Windows Normally" screen, I pressed "Enter" to do this and it just keeps going back to the same "Start Windows Normally" screen after it goes to the window screen to load up. I have noticed a "Blue square" with white writing in it flashes for less than a second before going back to "Start Windows Normally" screen, it is to fast for me to read. How can I get past this? (if I can)
Questa è una buona domanda?
Punteggio -1
Aggiungi un commento
1 Risposta
Have you tried booting to safe mode, to see if it will boot?
Punteggio 0
1 Commento:
I did with no effect, I've just tried start up with F8 (starting up at a safe point) and it has worked. Thank you for commenting.
da
Aggiungi la tua risposta
Gavin Hogan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 12
Tutti i Tempi: 1,037
