Salta al contenuto principale
L'HTC One SV è un elegante smartphone Android con funzionalità 4G LTE che unisce un audio di alta qualità grazie al sistema Beats Audio™
Power Button Works Intermittently
My Power Button on my HTC One SV is slowly becoming non-functional. at first it started with pressing the power button a couple times to bring it out of standby, then 3 times, then it started to need to be pressed hard. Now it won't work using my fingers, i have to grab something and push the power button in farther than my fingers could. is there a repair fix? or Contact HTC?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
same thing happen to me I sent the phone to HTC and they sent it back and said they did not have the parts for power switch cost me 56 bucks to ship with insurance , a rp rep called me a month later and said you are just out of luck you have to buy a new phone and they were done ,i got a micro switch and installed it on the board "wrong switch" but the phone works great not I don"t have a button that makes it look pretty on top now but better than HTC answer . Good luck to anyone who has a HTC one S V the power switch is not very good design and it falls apart easy in 1 week my new universal micro switch is stout and is working great ....
Punteggio 0
I fix mine :)
I found the fix here
Solution: compressed air and/or alcohol
I actually combined both ... and used a Deo Spray :)
Hope this helps others too.
Punteggio 0
Aggiungi la tua risposta
jfinley2003 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 9
Tutti i Tempi: 3,101
