Salta al contenuto principale
Rilasciato a giugno 2009 / Processore Core 2 Duo a 2,66, 2,8 o 3,06 GHz
Location of the WLED driver
Immagine
Can someone tell me where the WLED driver on this Macbook Pro? This is a Macbook Pro 15" 2.8Ghz Mid 2009 EMC 2324. I have also included pictures. Thanks in advance.
Immagine
Immagine
Immagine
I'm sorry, but I couldn't find the last three digits of my serial number.
Questa è una buona domanda?
Punteggio 2
7 Commenti
Kevin, not sure where you posted your images:-) use this guide Aggiungere immagini a una risposta esistente to post your images with your question. Also, it will help tremendously if you give us the last three digits of your computers serial number.
da
I just uploaded the pictures. Sorry about that.
da
Hey, no problem:-). do these look like the specs for your computer:" 2.53 GHz Core 2 Duo (P8700)
Intro Date: June 8, 2009 Disc Date: April 13, 2010
Order No: MC118LL/A Model No: A1286 (EMC 2324*)
Subfamily: Mid-2009 15" Model ID: MacBookPro5,4
Std RAM: 4 GB Std VRAM: 256 MB
Std Storage: 250 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
da
No, but I think this is it (mine has a 2.8 Ghz) :
Intro Date: October 14, 2008 Disc Date: March 3, 2009
Order No: BTO/CTO Model No: A1286 (EMC 2255)
Subfamily: Late 2008 Model ID: MacBookPro5,1
Std RAM: 4 GB Std VRAM: 512 MB*
Std Storage: 320 GB (5400 RPM) Std Optical: 8X DL "SuperDrive"
da
Kevin, check the EMC number on image #1 it shows EMC 2324. you sure about the EMC 2255?
da
Mostra 2 altri commenti
Aggiungi un commento
1 Risposta
Soluzione prescelta
Kevin, for the EMC 2324 as it shows on the images you uploaded, the LCD backlight driver has reference designator U9701. It is a LP8543SQX manufactured by TI. the datsheet is available right here. The part itself seems to be a bit hard to come by, but it is available :-) Hope this helps, good luck.
Immagine
Punteggio 4
3 Commenti:
Thank you very much for your help.
da
where can I get the replacement piece? thanks
da
Aggiungi la tua risposta
Kevin sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 18
Tutti i Tempi: 25,253
