Salta al contenuto principale
Il T-Mobile G1 è il primo smartphone commercializzato con il sistema operativo mobile Android. Rilasciato a settembre 2008.
Why does my camera/camcorder application force close?
I have rooted G1 running the latest Cyanogen 4.2.3.1. Unfortunately, my camera/camcorder app force closes and refuses to open. I have wiped, reformated the SD, restored to stock G1 ROM, even went as far as trying another ROM thats not Cyanogen (*GASP*), but everytime it force closes. I am thinking it might be a hardware problem, but I'm not sure. Help!
Questa è una buona domanda?
Punteggio 4
5 Commenti
Are you running 1.5 or 1.6?
da
I'm running CyanogenMod 4.2.5 which is based off of Donut 1.6.
da
Normally this should be asked as a comment, but I'll hold off on down-voting you since you don't have the rep for commenting.
da
sorry, i'm new, just got the code today, and don't understand this system entirely
da
try reheating the i.c around the camera,i repair phones fyi
da
Aggiungi un commento
5 Risposte
Risposta più utile
This intrigued me so I went into study mode. All I can say is I do not have an answer. The cam force closes even when phone is restored to T-mob stock configuration?
Help per my reading:
1. http://twitter.com/cyanogen
2. http://wiki.cyanogenmod.com/index.php/Ma...
3. http://forum.xda-developers.com/showthre...
good luck.
Punteggio 2
1 Commento:
The cam does force close when the phone is restored to stock configuration. I have a feeling that its a hardware related issue at this point.
da
I'd assume then its a cyanogen bug, the latest ROM is not 100% compatible with 1.6, try a complete restore to the original rom and it should probably work.
Punteggio 2
it sounds like it can't find the files in order to run
check and see if you accidentally moved or deleted some of the files
Punteggio 1
update software of camera
Punteggio 0
After clicking images, images are shown reverse
Punteggio 0
Aggiungi la tua risposta
Walter Galan sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 15
Tutti i Tempi: 7,987
