Salta al contenuto principale
Il Samsung Galaxy Nexus fa parte della linea di dispositivi top di gamma NEXUS di Google. È dotato di un display HD Super AMOLED, schermo curvo e sistema operativo Android versione 4.0 Ice Cream Sandwich.
How to fix broken screen myself?
I dropped my Verizon Galaxy Nexus (SCH-i515) and the screen's outer glass broke. The display itself and the digitizer (touch sensor) seem to work just fine. Is there a DIY method of replacing the broken glass? I've seen the part (the glass front panel) online for anywhere from $15 to $25, but I've also read that the glass and the digitizer are somehow glued together such that it's necessary to replace the whole display (around $150-200!).
Any advice/links/tips would be most appreciated, including a list of needed tools to get this done. I'd just buy a new phone, but I still have a year left on my contract!
Thanks!
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Chris, check the teardown on here. It will give you a basic idea about what you are up against. It will also show you the tools needed. Here is also a decent video. Yes, the screen is a display assembly and I suggest to replace the assembly, even so you can probably purchase the individual parts, but they are extremely difficult to separate. Hope this helps, good luck.
Punteggio 1
Aggiungi la tua risposta
Chris sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 2
Ultimi 30 giorni: 16
Tutti i Tempi: 3,138
