Salta al contenuto principale
L'Aspire 7741Z è un notebook Acer con un display widescreen da 17,3" HD con retroilluminazione a LED.
Replacing internal hard drive
My external hard drive failed for the 3rd time so I would like to replace the actual internal hard drive. For this device, what type of hard drive should I buy? Is there limitations to the physical size/dimensions and hard disk capacity? What tools do I need to open and how do I go about replacing the hard drive?
Thanks in advance.
Questa è una buona domanda?
Punteggio -1
1 Commento
Kat, great video on here http://www.youtube.com/watch?v=6k-FnZze3... It's a straight forward task, not to complicated. All you seem to need is a Phillips #1 or #0... remember that when you change the HDD, make a guide for the rest of us. Hope this helps, good luck.
da
Aggiungi un commento
1 Risposta
Soluzione prescelta
IFIXIT doesn't currently have a repair guide for this model. It appears someone has started the guide but didn't get a chance to finish it {how about helping us out}. It's people like you that make IFIXIT what it is.
As to the tools you'll need looking at the other Acer guides it appears you'll only need a Phillips #00 Screwdriver. But until someone documents things you might get a surprise once you get inside. You might want to get the IFIXIT tool kit with the plastic sponger tools.
As far as the HD its' self, looking at a few parts suppliers you'll need a 2.5" 9.5 mm high SATA II HD.
Punteggio 1
Aggiungi la tua risposta
Kat sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 12
Tutti i Tempi: 1,899
