Salta al contenuto principale
La PowerShot SD850 IS Digital ELPH è una fotocamera digitale con un sensore CCD da 8,0 Megapixel e uno zoom ottico 4x. Il prodotto è stato rilasciato nel maggio del 2007.
SD950 IS disassembly differences from 850
What differences will be in countered between 850 guide and my 950 IS. I got sand in the Len mech won't open.
Big question is can the lens mech be cleaned and how?
Questa è una buona domanda?
Punteggio -1
2 Commenti:
your camera is a PowerShot SD950 or a Digital Elph/IXUS 950 IS?
da
thanks for asking - Powershot SD950IS
da
Aggiungi un commento
1 Risposta
Hi Joe,
I just used this guide to take apart my 950 IS to swap out the screen from another one. There really isn't much different, one or two less screws to take out and the cables for the LCD look a little different but it's essentially the same process to remove it. Just be sure to keep track of which screws go where and you should be fine.
I bought a broken 950 IS off ebay to use for parts so I may put that back together and create a guide for disassembling that at some point in the future.
Cheers,
Martin
Punteggio 0
Aggiungi la tua risposta
Joe sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 13
Tutti i Tempi: 757
