Salta al contenuto principale
Modello A1136 con 30, 60, o 80 GB di hard disk con plastica frontale bianca o nera
797 Domande Visualizza tutte
apple support error
hello i got my ipod every time i turn it on my Ipod say www.apple.com/support/ipod?
i go there but theres no answes how to fix it. i tried doing a hard reset but that message still pops out? how can i fix this????
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
4 Risposte
Soluzione Prescelta
Hi,
when the iPod says www.apple.com/support/ipod it most likely means that you have an hardware issue.
Connect the iPod to a PC and tell us what happens. If the iPod is unrecognized by the explorer and iTunes, it most likely means that the hard drive or the hard drive cable is damaged/broken. If the iPod is recognized by the explorer and not by iTunes try to restore the iPod via iTunes.
Punteggio 1
2 Commenti:
Easier said than done if iTunes doesn't recognise the iPod
da
Forgot to say that the iPod should be set to "Disk Mode" previous connecting.
http://www.command-tab.com/2006/03/30/hi...
da
Googling this message brought up a message the the ipod needs to be reset. I have included the URL for you. Ralph
http://www.zolved.com/synapse/view_conte...
Punteggio 0
iPod Videos are very finicky! Please take a look at the troubleshooting guide for further info.
Punteggio 0
Im having this same problem. The ipod is recognized by itunes, but when after the ipod is "prepared for recovery", I just get that same error message again :S. Does this mean it's the hard drive cable?
Punteggio 0
1 Commento:
cjdrake, this question is almost 3 years old. I suggest you ask your own question and give more detail.
da
Aggiungi la tua risposta
djhugodaniel sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 19
Tutti i Tempi: 3,798
