I had the same problem, no solution from the internets worked. What I did was to start my computer with Ubuntu to check if the hardware was OK, which it was. Then back to Windows 10 and the speakers were working again,
Apparently, Windows skiped to comunicate to the speakers to put them on “working mode”, but saved somewere in its memory that it has, so no matter what I did, Windows continued to “think”: I already told the speakers to work ,so they should be ready to work. And no matter what reinstalation, update or restart you do, Windows didn´t bother to comunicate with the hardware again to check if indeed it was in working mode. Ubuntu did it as soon I started with it, and left the hardware on that state, so when I went back to Windows it was properly set.
Ubuntu 1 - Windows 0
Votato
Annulla
Punteggio
I am experiencing exactly the same. I did a system restore and all was fine again. Today suddenly, the sound is gone again. HELP!!
da Pat Haywood
Wow! Exactly what happened to me! I checked too.. but shutting down and restarting helped.
da PREETI
It happened to me so I restarted it...didn't work,muted it then unmuted it...didnt work...I NEED HELP!!!!!!!!!!!!!!!!!!! Please help meh <3
da FreyaRubyPritchard
my AA1 722's sound goes out every 2-3 mins for about 30-60 seconds and comes back, very irritating. I have not found a fix yet, system restore does nothing. I've even checked with the registry configuration. Is there a fix?
da meranber
i am using acer e1-421 and same thing happened. although i tried restarting it. the sounds returned to normal only for few minutes then it goes mute again. i don't know what to do.
da Lea Morales
Mostra altri 12 commenti
