Salta al contenuto principale
L'HTC Desire HD è uno smartphone Android prodotto da HTC Corporation.
Screen replacement help me
I have an htc desire hd phone with broken screen but the phone works smoothly and finely.
Should i have to replace the whole lcd screen or just the screen digitizer.
And if i have to replace only the screen digitizer , is it normal to replace the screen digitizer ande is it easy???
>>help<<
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione prescelta
Amit Pathak , yes it is possible, but it is anything but easy. Check this video and this one for more information. Some more instructions on here as well. You will need a heat source to remove the digitizer from the screen. Check on this question as well. Hope this helps, good luck.
Punteggio 3
Thank you for that informations.
Punteggio 0
Aggiungi la tua risposta
Amit Pathak sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 0
Ultimi 30 giorni: 3
Tutti i Tempi: 1,898
