Salta al contenuto principale
Serie di portatili Windows da 15,6" di Acer destinata a utenti occasionali.
Acer aspire internal speaker
The right chanel in the PC speaker dont't work. If I connect to external speaker it's ok, so the problema is in the hardware. It's a production problema because other ACER's I tested have the same problem.
Questa è una buona domanda?
Punteggio 4
Aggiungi un commento
3 Risposte
I have read a lot about those Aspires with only one speaker.
I opened mine and had an extra connection for another speaker on the main-board but no speaker present.
Open yours, hope it has the connector and find some other speaker that fits the space you have there and fix your sound.
Punteggio 0
Yes. You are right. I have the same computer which doesn't give the sound from two speaker. When i bought it, i realised that there is no sound from one of them. First i think it is broken but i understood from your writing that it is manufacturing problem or they did it on purpose. Thank you.
Punteggio 0
Same problem opened it just 1 speaker tried to install 2nd speaker no luck did not work
Punteggio 0
Aggiungi la tua risposta
Pedro Bicho sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 2
Ultimi 30 giorni: 14
Tutti i Tempi: 4,029
