Salta al contenuto principale
La Sony Cyber-shot DSC-W55 è stata presentata all'inizio del 2007. Rispetto al modello precedente, dotato di una fotocamera da 5,1 megapixel, questa versione è stata aggiornata con una fotocamera da 7,2 megapixel e dispone di 56 MB di memoria interna.
Flash does not work!
Turned camera on and heard a loud pop. Removed and charged NP-BG1 battery. Reinstalled charged battery, but battery discharged rapidly. Bought new NP-FG1 battery, charged battery, installed battery and got "E91:01 error code with flash symbol flashing on LCD screen. Camera takes pictures, but flash does not flash. I suspect the capacitor blew when the loud pop was heard. Any suggestions?
Where can I buy a replacement capacitor without buying the entire flash unit?
THANKS in advance.
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
1 Risposta
Soluzione prescelta
Dick, the error code that you are getting is related to an issue with the flash or light on your camera. There are a two things that may have made that noise, Either your flash bulb, or your flash capacitor. Follow [http://he error code that you are getting is related to an issue with the flash or light on your camera. It's usually just replacing the flash bulb on the camera,|this guide] to either replace the capacitor or the whole assembly. the part numbers are as follows:
1-479-663-31 FLASH UNIT
1-112-819-11 ELECT 97uF 315V Capacitor
you can get it from here
A-1231-877-A ST-133 BOARD, COMPLETE
Immagine
Hope this helps, good luck.
Punteggio 2
3 Commenti:
THANKS "oldturkey03", I plan to disassemble the camera and investigate further this week. Dick
da
На плате st-133 посмотри контакты конденсатора и детали которая распаяна под лампой . Может и в самом конденсаторе дело ! Тратить надо ...
da
сперва саму батарею проверь . а потом дальше ...
da
Aggiungi la tua risposta
Dickie sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 5
Ultimi 30 giorni: 17
Tutti i Tempi: 2,243
