Salta al contenuto principale
Supporto per la serie di orologi Nike+ FuelBand per il monitoraggio dell'attività fisica e della salute, rilasciata per la prima volta all'inizio del 2012.
How to replace the battery
My Nike FuelBand
I shipped and after 5 minutes become empty !!!
Questa è una buona domanda?
Punteggio 2
Aggiungi un commento
2 Risposte
Soluzione prescelta
According to a teardown of this device posted on youtube by mikeselectricstuff there are two curved lipo cells soldered in place in this device. You need to exercise care when working with lipo batteries so you dont accidentaly short them out. Perhaps you could try ebay and see if you can find the right type of curved cell there. Bending a normal lipo cell into the reqiured curve is not something you should try as this could make the cell prone to exploding/cathing on fire.
Punteggio 0
2 Commenti:
thank you but I'm Out US warranty cover this Problem ?
da Condividi
I am a little confused by your reply. Are you asking if this is something that would be covered by warranty? If you are unsure about the repair and your device is still covered by warranty you should contact the manufacturer and ask if it is covered.
da Condividi
Found this, for the fuel band
http://www.batteryfromchina.com/Datashee...
Punteggio 0
Aggiungi la tua risposta
Ahmed sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 7
Ultimi 30 giorni: 45
Tutti i Tempi: 30,067
