Software component of memory board replacement
After replacing the board does the computer automatically recognize it? Other than physical replacement is there anything else to do?
Questa è una buona domanda?
Kevin, most likely you will find that you need to reinstall a few drivers for the logicboard. Those are usually available at the motherboard manufacturers website, and/or you may even get the driver disk with your board. Everything else should be okay. Hope this helps, good luck.
Ultime 24 ore: 3
Ultimi 7 giorni: 7
Ultimi 30 giorni: 33
Tutti i Tempi: 736
