Salta al contenuto principale
Riparazioni e modifiche per Chevrolet Cavalier del 1993.
How do you replace ignition switch
How do you replace ignition switch on 93 cavalier
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
Gary miller, here is what the manual says:"
Ensure front wheels are pointed straight ahead.
Turn ignition switch to Lock position and remove SIR or AIRBAG fuse.
Remove lower left sound insulator.
Remove connector position assurance (CPA) lock and disconnect yellow two-way SIR harness connector at base of steering column Steering wheel.
Remove Cover screws (22).
Remove upper steering column cover (3).
Remove lower steering column cover screws (26) and lower steering column cover (24).
Move shift lever to "PARK" position and key to "OFF-LOCK" position then remove the key.
Remove the two ignition switch mounting screws (21) and ignition switch assembly (20).
Remove all wire connectors from ignition switch assembly (push locking tabs to remove the wires" Hope this helps, good luck
Immagine
Punteggio 2
Aggiungi la tua risposta
Gary Miller sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 2
Ultimi 7 giorni: 6
Ultimi 30 giorni: 26
Tutti i Tempi: 3,879
