Extraction of broken earphone jack for iPad 2 if Crazy Glue method not working
materials needed:
new 1/64th inch drill bit with good grade electric drill
#4 by 1 inch sheet metal screw
small phillips head screw driver
1 "brad" nail (very thin and about 1 inch long)
needle nose pliers
method:
apply moderate pressure while drilling about 3/4 full speed to create hole in embedded piece. Metal collar can be coaxed out with nail leaving remaining plastic core and plug covered with thin metal cover. Gently continue drilling to make an eccentric hole between the stuck piece and sidewall of plug receptacle. Screw the sheet metal screw into the hole about 6 turns. Do not screw in excessively or risk pulling the entire receptacle out of iPad. Grab the screw with pliers and pull. Repeat a little drilling, screwing in and pulling until the piece comes out.
Conclusion: With a bit of computer knowledge and patience this method worked in my situation and the earphone jack receptacle is functional although I will use a bluetooth headset in future. I did not try to glue method first.
Votato
Annulla
Punteggio
The whole thing of an aux chord got stuck inside you can see the back and everything i tried a pen paper clip tweezers pliers toothpicks thumb tacks nails pick
Please help me!!!
da joseph valentin
Joseph, get a GripStick. It is a tool that is a proven, safe, reliable, and cost-effective way to solve this pesky problem. It was specifically designed to solve this, and was successfully funded on Kickstarter.
It is now available for sale on our website: http://nightek.com.
Watch a video of it here: https://www.youtube.com/watch?v=Ii5OKvtN...
da Nito
