Salta al contenuto principale
Rilasciato il 22 novembre 2005, il controller wireless per Xbox 360 è il controller di gioco principale per la console videogame domestica Xbox 360 di Microsoft.
Central guide button has jammed
Right heres the problem, the guide button in my limited editionxbox 360 controller has jammed in place an now trys turning off the xbox every few minutes. I've not spilt anything on it, this is the only controller I've got thats suffered this problem, I've tried cleaning it with a mild alcohol cleaner which did nothing I also tried giving it a quick blast with compressed air which did nothing, is their anything I can do to fix this without soldering.
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
1 Risposta
Soluzione prescelta
James Roff, take a look at this guide. Clean all components with alcohol, all rubber and plastic components with mild detergent,. Take a look at the corresponding ends and see if you can find where it jams.
Punteggio 2
3 Commenti:
Cheers I'll give it a shot and get back to you on the results
da
Had to use a fine glass paper to smooth the guide button as it was rough and stocking but apart from that your advice was spot on =) cheers
da
Thank you for accepting my answer. Best of luck to you.
da
Aggiungi la tua risposta
James Roff sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 14
Ultimi 30 giorni: 25
Tutti i Tempi: 7,314
