Salta al contenuto principale
La stampante a getto d'inchiostro Epson Stylus Photo 1400 stampa in alta qualità fino a 33 cm x 48 cm. Inoltre, supporta la stampa su CD/DVD.
alternating red lights flashing
Think I need re-set procedure for 1400 I have the re-set procedure for my 1280
Questa è una buona domanda?
Punteggio 0
Aggiungi un commento
3 Risposte
Risposta più utile
Pat DIACCA Topp , try this:"
Download the Epson 1400 from here.
Unzip the file. Run the Adjustment Program for Epson Stylus Photo 1400 printer. Select the right port for usb. The port should be selected in Auto Selection. Click Particular adjustment mode.
Point on Waste Ink Pad Counter and press Ok.
Press Check Button to check the Waste Ink Pad Counter.
Click Initialization to reset.
Turn off the printer and turn it on again.
Punteggio 2
please repost the link to download from. thanks
Punteggio 0
1 Commento:
Lynn, don't you know how to Google? Please put a little effort into finding the answers you need so you will not always be at the mercy of the selflessness of others.
da
hello
I have got epson 1400 . power is off and paper and ink lights are flashing . please help
Punteggio 0
1 Commento:
hi my printer(1400) won't print anything whenever I try to print it stacks and then two lights starts blinking on the computer it's saying fetal error paper jam please help me
da
Aggiungi la tua risposta
Pat DIACCA Topp sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 1
Ultimi 7 giorni: 10
Ultimi 30 giorni: 29
Tutti i Tempi: 6,099
