Salta al contenuto principale
Released online on January 16, 2009, the Inspiron 1545 is a 15.6" budget PC laptop available with 3 or 4 GB of RAM. It succeeded the Inspiron 1525.
How do I bypass the password authentification system?
When i turn the computer on, it says "this computer system is protected by a password authentification system . You cannot access the data on this computer without the correct password". I did NOT put this on here! How could this have happened, and how do i get oast it so i can use my own computer again? Please help!
Questa è una buona domanda?
Punteggio 56
23 Commenti
bY PASS THE PASSWORD AUTHENTIFICATION SYSTEM HOW SOLVE PROBLEM
da
don't have reset disk bought this at savors it got donated without anyone being told of the password how can I bypass this
da
had this problem on a work computer...Dell Opti 9020. We don't use this feature so it should not have come up...Contacted Dell, and they generated a password...Will probably verify ownership though.
da
go to bios-pw.org, get your password by entering the code/serial tag, if control+enter doesnt work, press left control+enter twice
da
i have dell inspiron 1545 it pop-up a sreen saying this computer system is protected by a password authentication system how can i bypass it . by dj-sn@cks
da
Mostra altri 18 commenti
Aggiungi un commento
10 Risposte
Soluzione Prescelta
Heather, there is no way of bypassing it. It is the BIOS password and can not simply be bypassed. You can check on the Dell support site and try to follow those instructions. Anything else, you will have to call Dell and see if they can issue a standard password, based on your computers models number etc.
Punteggio 31
11 Commenti:
I have a Dell latitude d630 and I have the same problem, how can you bypass this!
da
Hola tengo el mismo problema con una dell latitude E 7470. Etiqueta de servicio #GWBJLC2
da
You used to be able to take the battery and the CMOS battery out and it would reset.
Not sure on these Dells though - Oldturkey seems to know his stuff ;-)
da
Nothing like computer geeks... You guys are the best... Nerd on forever
da
Well this man walked me through my Imac LCD display problem, and during the holidays yet. This Imac girl, the one with all the wrong screens . Well it took me all this time to find the right one for the right price. Still need one more, and have 3 to sell. Any way i just wanted to thank you so much for helping me out. So everybody out there, he knows what he's doing, so listen to him he's great.
Lynn
da
Mostra altri 6 commenti
For those, whom are stucked, perhaps can try this
https://bios-pw.org/
Punteggio 21
17 Commenti:
@ Augustine
Yea, I tried that link but didn't work for me. ,Dell inspiron 1440.. #CKXXKJ1-595B, is protected by password authentication system,,,
da
I went to that site and it ask for a code. What's the code?
da
After trying all the codes generated I noticed tiny print below them. Press CTRL + ENTER. The second code generated by that link solved my gumbo-lock. Thank you very much. BTW folks if this 55 yr old woman can do it so can you.
da
Gracias... muchas pero muchas gracias, me sirvió ... este es el modelo de mi laptop:
DelI Inspiron 1420 series
El sistema mostró varias opciones de contraseña, la segunda fue la correcta.
da
Thank you, Augustine. Worked for me twice; each time required Ctrl + Enter, (Enter was the only instruction given on the unlock screen); each time it was the code next to "Dell from serial number" that worked. By the way, the code the site asks for is the serial number with the four character extension that shows up on the unlock screen where you're asked for the password.
da
Mostra altri 12 commenti
Go into the bios, and go down to security and select system password and it will say type in password and press enter twice and it will remove the password
Punteggio 3
8 Commenti:
the software does not allow me to get to the bios, or anything else just the page asking for the password the authetication system.
da
bronzen1, what model computer do you have and what have you tried?
da
Same thing happened to me...used F8 on reboot, accessed set up utility, reset a new password and now.....stupid authentication screen! Not crazy about messing with cmos batery ....
da
burn your computer to the ground that should do the trick
da
mine is doing the same thing and it sucks idk how to get into it!!!
da
Mostra altri 3 commenti
It seems like a BIOS password and the best way to reset BIOS password is to take the motherboard backup battery apart. Simply just take out the small battery out and leave it like this for about 10 mins and then put the battery back inside the slot then power on your PC this shall remove the any BIOS password.
Punteggio 2
2 Commenti:
I don't think removing the battery deletes the password. It does delete other settings.
da
#5634mj1-1f5a,
da
Go to: https://biospassword.eu/dell-free-passwo...
enter your service tag
enter the generated password press ctrl, enter, enter
Thank me later
Punteggio 0
2 Commenti:
I'm locked out and my keyboard and mouse arent are!! I'm lost as to what I can do?
da
Thanks so much, it worked
da
Solution is very simple you have to crack the password, Its really easy.
Go to this website enter the code which is showing in your pc and generate a new password.
Enter it and you are done.
https://okadtech.com/this-computer-syste...
This will help you to do it step by step.
Hopefully this will help you.
Punteggio 0
I have a problem with the bios password for the SSD hard disk. I want to solve the problem. The error code is 010704637HP-2A7B.
Punteggio 0
3 Commenti:
@gameapk this is not going to work for your drive. I don't think there is a hack for an encrypted drive.
da
I want a solution for that
da
I did not create any password
da
To bypass that password simply open the casing, locate the jumper wire on the main board labeled pswd, disconnect and restart computer. Easy peasey.
Punteggio 0
#5634mj1-1f5a,
Punteggio 0
THIS is why you SHOULD have a BIOS p/w on any computer that others may have access to.
Because, if you didn't put the password in, someone else did because there was no password needed for them to do it.
HOWEVER, now you must remember the password somehow. I highly recommend a password manager. Bitwarden free works well for me.
Punteggio 0
Aggiungi la tua risposta
Heather sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 110
Ultimi 30 Giorni: 448
Tutti i Tempi: 170,111
