Salta al contenuto principale
La Mazda Millenia è un’auto executive prodotta dalla casa automobilistica giapponese Mazda tra il 1993 e il 2002.
fuel pump fuse location
No power to the fuel pump. relay tested good. where is the fuel pump fuse located on this car?
Questa è una buona domanda?
Punteggio 1
Aggiungi un commento
2 Risposte
Soluzione prescelta
johnelmore47, looks like the Millenia has got one. It is a 15 Amp fuse and should be marked engine in the fuse box. It also uses a resistor. Here is what the manual says:
Fuel Pump Control System
System inspection
1. turn the ignition switch to START and check operation of fuel pump relay and fuel pump resistor and relay by listening for their operating sound.
2. If no sound was heard, check the fuel pump relay and duel pump resistor and relay (speed0.
3. If the fuel pump relay and fuel pump resistor and relay(speed) are normal, check voltage at following terminals
ECM terminal 1H (Ignition switch start signal)
ECM terminal 1AF(Fuel pump relay)
ECM terminal 1AJ (fuel pump resistor and relay)
Fuel Pump Relay
Inspection
1. Remove the cruise actuator
2. remove the fuel pump relay.
3. Apply battery positive voltage and check continuity between terminal of the relay by using an ohmmeter
4. If not as specified, replace the fuel pump relay.
Immagine
Fuel Pump Resistor and relay (Speed)
Inspection
1. Disconnect the fuel pump resistor and relay connector. Measure the resistance between terminals A and B by using an ohmmeter
Specification:0.38-0.42 ohm
2. If not as specified, replace the fuel pump resistor and relay (speed).
Immagine
Here is the wiring diagram
Immagine
Immagine
Immagine
Punteggio 5
2 Commenti:
Do u remove the backseat to install the fuel pump on a 2001 Mazda millenia
da
Yes you'll have to.
da
Which fuse do I check for rear break lights? My lid to fuse box is missing. 1995 929
Punteggio 1
Aggiungi la tua risposta
johnelmore47 sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 5
Ultimi 30 giorni: 34
Tutti i Tempi: 37,319
