Salta al contenuto principale
Guide di riparazione, smontaggio e soluzione problemi per la prima generazione di Apple iPad con Wi-Fi, disponibile con 16, 32 o 64 GB di spazio di archiviazione. Rilasciato nell'aprile 2010. Identificato dal numero di modello A1219. Le riparazioni sono semplici e non richiedono calore.
I cannot open applications
i cannot open my other applications
Questa è una buona domanda?
Punteggio 2
1 Commento
What is going on with my ipad
da
Aggiungi un commento
2 Risposte
Soluzione prescelta
Try closing all the open applications. Double click the home button, this will bring up all the apps that are currently open on the dock. Click and hold on one of the apps until you see a red minus sign on all of the apps. Then close all the apps.
Here is a video in case you get stuck: http://www.youtube.com/watch?v=-BpKelKli...
Sometimes what happens is that people don't know how to properly close apps and eventually they have so many apps open that the iOS device becomes super slow and then you start getting problems running the apps. I have seen this many times with my customers iOS devices.
If this doesn't work then try reseting the settings in the settings app under "general"
Another thing to try is hold down the sleep/wake/power button on the top right and turn off the ipad then restart it.
Punteggio 0
I am unable to open the settings app... HELP!! I'm trying to figure out why my moms iPad 1st generation continues to cut off while your in the middle of it...
Punteggio 0
Aggiungi la tua risposta
marc paul bael sarà eternamente grato.
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 8
Ultimi 30 giorni: 39
Tutti i Tempi: 4,008
