Salta al contenuto principale
La famiglia MacBook è stata introdotta nel maggio 2006, sostituendo l'iBook nel ruolo del laptop Apple indirizzato al mercato consumer.
NO SOUND OUTPUT. Help
I have been in the sound settings but I cant ajust the sound as it is not highlited. The message in the box says; THE SELECTED DEVICE HAS NO OUTPUT CONTROLS.
How can I activate?
Many thanks
Questa è una buona domanda?
Punteggio -1
1 Commento
- vote for asking the same question three times in 7 hours. Try to stay with your original question please
da
Aggiungi un commento
1 Risposta
Soluzione Prescelta
Mark,
The computer is most likely stuck in the digital output mode. If you look in your headphone jack, you will probably see a red light. Most searches for support will suggest a toothpick to disengage the tab inside the headphone jack.
Others have had success by inserting a 3.5mm plug in and out repeatedly until the tab releases and the computer no longer thinks there is a plug in that jack.
Here is more on that.
Good Luck
Frank
Punteggio 2
1 Commento:
+1 Ralph
da
Aggiungi la tua risposta
Mark sarà eternamente grato.
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 809
